So my redneck friend told me an old trick to plugging a leaky radiator. Add about a tablespoon of cinnamon to the reservoir. He swears it works. Never needed to try it but just wondering if anyone heard about this or any other quirky fixes.
Leaky radiator? just add cinnamon
egg= tested and proven on mythbustersRenting my rear wheel bearing tool kit. SIR
Using anything as a stop leak is a really bad idea. It may, temporarily, plug the leak, but it will gunk up the rest of the cooling system and reduce it's efficiency. And it is hard to clean the stuff out. In extreme cases the engine will have to be removed and torn down and the radiator, heater valve, and core replaced.
In most cases a radiator leak is the result of an old radiator. E30 radiators tend to last a long time, but I'd don't trust one that is over 10 years old. The plastic bits have gotten pretty brittle by then. Best to replace it before it becomes a problem.The car makes it possible, but the driver makes it happen.
