I need some help diagnosing a weird noise. It appears to be coming from the front of the car since I can occasionally feel a vibration in the steering wheel. It's an auto (shut up!) and only happens when accelerating from a stop or very low speed and goes away after accelerating past 15-20 miles (my guess, but its a low speed). It appears to only happen once I've driven a few miles. It's a hum or groan that comes and goes (as in hum, hum, hum, hum) and it doesn't matter if you are going straight or turning.
Front Susp. Parts Replaced:
tie-rods
control arms/bushings
strut/shocks
E36 ps rack
hubs/wheel bearings (only parts replaced to fix this problem)
I replaced everything but the wheel bearings mid last year. When I replaced the wheel bearings a few weeks ago due to this noise I thought the problem was fixed because the noise was gone. Two days later the noise was back. So i thought maybe my brakes were bad (warped rotors, rubbing, etc) but my own visual check and a shops inspection didn't find a problem with the suspension or brakes.
The weird thing is that after I got the car back from the shop the noise was gone for the entire day, just like when I replaced the wheel bearings. On my way to the shop, noise. After the shop, no noise... until the following day.
In both cases the front was lifted to remove the wheels. Could this be a weight shifting issue? I bring this up because someone may recommend that my guibo, csb or driveshaft may need to be inspected but I just have trouble linking these parts to the noise when I feel it in the steering wheel and the noise was "gone" after the front was inspected. I should mention that I don't get the clunks that people experience with a bad csb or driveshaft.
So any clues? Any and all help is appreciated. Thanks.
tie-rods
strut/shocks
E36 ps rack
