I tested my ignition coil for a spark. Its getting a spark but it wont jump at all. It wont spark until its grounded. Does this mean I have a bad coil or is the weak spark that its putting out ok. The spark is blue it just wont jump. Please help. Thanks
Question about an igntion coil
Tags: None
Re: Question about an igntion coil
How are you testing the coil for spark? The way to test an ignition coil properly is to measuer the primary and secondary resitance of the windings with an OHM meter.Originally posted by formula driverI tested my ignition coil for a spark. Its getting a spark but it wont jump at all. It wont spark until its grounded. Does this mean I have a bad coil or is the weak spark that its putting out ok. The spark is blue it just wont jump. Please help. Thanks
Follow the procedure in the Bentley or even the Haynes for an explanation.
James
I was without my ohm meter for the day thats why I tested it the way I did. I tested it today the proper way and its in fact bad.
Hey man, are you SURE this is a bad coil? I had it in a running car and it was working fine - I don't sell crap ;) If it does indeed test to be bad, let me know, I'll send you another one. I think I've got one around here somewhere.Originally posted by formula driverI was without my ohm meter for the day thats why I tested it the way I did. I tested it today the proper way and its in fact bad.Comment
The DME grounds it to activate spark. That's how the Motronic controls the spark advance.Originally posted by formula driverI tested my ignition coil for a spark. Its getting a spark but it wont jump at all. It wont spark until its grounded. Does this mean I have a bad coil or is the weak spark that its putting out ok. The spark is blue it just wont jump. Please help. ThanksAdam Fogg- '88 M3
Common sense- It's the new 'gifted'Comment
Yea... it was bad. I tested it and it was bad. I ended up buying a new one. Dont worry about it though. Ill continue to buy from you. I know you didnt mean to send me a bad part.Originally posted by BeemerfanatikHey man, are you SURE this is a bad coil? I had it in a running car and it was working fine - I don't sell crap ;) If it does indeed test to be bad, let me know, I'll send you another one. I think I've got one around here somewhere.Originally posted by formula driverI was without my ohm meter for the day thats why I tested it the way I did. I tested it today the proper way and its in fact bad.
I tested the old coil and got a weak spark so I bought a new coil and the spark was jumping. So I put a plug in the boot and grounded it, no spark! I tested the coil again and no spark at the coil. Why would it do this. It was working fine one sec then not the next???? Could I have a bad ECU?Originally posted by AdamF 88iSThe DME grounds it to activate spark. That's how the Motronic controls the spark advance.Originally posted by formula driverI tested my ignition coil for a spark. Its getting a spark but it wont jump at all. It wont spark until its grounded. Does this mean I have a bad coil or is the weak spark that its putting out ok. The spark is blue it just wont jump. Please help. Thanks
