Valve cover bolts stripped
  • Nick_S
    • Apr 2011
    • 3658
    So I went to change my valve cover gasket today and noticed some of the bolts were loose. Just though the PO hadn't tightened them all the way. Pulled it off, cleaned, painted the valve cover and painted. While drying I took the bolts to my wire wheel to clean them up and noticed a few of them had some metal on them, which ended up being threads. Went to re-install and sure enough, a few of the bolts don't grab anything.
    Not real stoked at this piece point but unfortunately my other car is down with some alternator troubles so I had no choice but to put it back together. Tightened all the non damaged bolts and fired it up and it's not leaking from anywhere and runs fine but I'm not happy with this. Should have my Focus back running this week so I'd like to tackle this issue before it gets any worse. It's supposed to be nice this week so I can ride my bike to work so I don't drive it much.
    But I'm not real sure what should be done? Re-thread with a larger thread pitch? Or have them heli-coiled? They appeared to be heli-coiled from the factory so I'm guessing that's the most ideal route to go? Any help or insight would be appreciated. Never had an issue like this and really don't want to damage the head. Oh and should have mentioned, it's an M42.
    Thanks
    Nick
    91 318is M50 swapped
    05 Honda Pilot
    24V swap thread
    I'd install TimeSerts, but you could use Helicoils or rethread to the next larger side. As far as I know, the original configuration would have been plain threads into the aluminum of the head.
    • twistednut
      • Nov 2007
      • 272
      Can't really go to the next larger size since it is a special bolt that doesn't allow you to completely crush the gasket. Size for a TimeSert or Helicoil is m6x1.0.
      what you did to this car is like getting a supermodel naked and willing to do anything you please. now here you are faced with ths once in a lifetime opportunity and then you squander it by making her fuck you in the butt with a 24" strap on. you are a sad, silly little boy.
      • Nick_S
        • Apr 2011
        • 3658
        Thanks man that's a huge help so I don't have to search for size. Yea that was my thinking on rethreading. There isn't any material to re-thread, really makes you wonder how someone overtightned it so much to pull the threads out. BTW, call me ignorant but what exactly is Timesert?
        05 Honda Pilot
        24V swap thread
        • !kid
          • 1362
          stripped out threads, damaged threads, blown out sparkplugs, stripped thread, stripped out theads, helicoils, ford sparkplug repair, repair ford sparkplugs blew out with time-sert, thread repair problems, spark plug ford blown, blew out ford sparkplug, stripped theads, threads stripped out, threads got stipped out of ford sparkplug, repairing stripped threads, thread repair kits and inserts, repairing sparkplugs threads, sparkplugs threads have stripped out, screw thread inserts for striped out threads, automobile threads blown out, motorcycle threads stripped out threads, not helicoil use time-sert thread repair, screw thread insert, inserts for screw threads, screw thead inserts have stripped out
          :borg:
          • Nick_S
            • Apr 2011
            • 3658
            Thanks, those seem like a better option than helicoils.
            05 Honda Pilot
            24V swap thread
            • BrewCity11
              • Mar 2008
              • 2335
              This happens all the time on M42s. I've helicoiled a bunch of those. Annoying to do but not difficult.
              turk@gutenparts.com
