car jolts when letting off and going on gas.
  • peytonracer4
    • May 2011
    • 524
    whenever i'm coasting and i push in the gas the car jolts. and when i let off the gas it also jolts like something in the driveshaft is loose.
    what could this be? guibo maybe?
    thanks
  • 801coppertop
    • 293
    Maybe im totally off base here, but it could be your subframe bushings, or maybe your diff bushing. Not ruling out the guibo though, when was it replaced last?
    • Simon S
      • Oct 2004
      • 3758
      Could be..
      Are you able to look at it ?
      When was the last time you replaced the flex disc/guibo?
      -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
      • Simon S
        • Oct 2004
        • 3758
        Also possible candidates..
        One way or another - OP will need to LOOK at the possible candidates - or take the car to a shop for inspection.
        • peytonracer4
          • May 2011
          • 524
          i'll take a look at everything that was mentioned.
          this car was just bought very recently and doesn't have records so i can't tell when anything has been replaced. unfortunately.
          • Balkanac
            • Apr 2011
            • 50
            Could be loose diff internals too, or the joints (driveshaft to g'box and driveshaft to diff)
            1991 BMW 318is Brilliantrot
            1998 Jeep Cherokee TD Black
            • Sagaris
              • Sep 2009
              • 2243
              Engine mounts are cheap, easy, and commonly a cause of that sort of feeling, however there are other things mentioned above such as sloppy gears+bushings that could also generate the issue. Engine mounts are a great first step though.
