When I first bought the car, my passenger window didn't work. I tapped on the motor a few times with a hammer and it worked for a good 3 months, and then gave out again. I tried diagnosing the problem after much laziness last week. I tried tapping the motor with a hammer again but no success. When I press the button, I can hear a "click" coming from my window, but the motor isn't moving. I have the early style regulators so it's cumbersome as hell. Any ideas?
Window regulator help
Tags: None
unplug the plug that goes from the window switch to the motor (on late model window motors it's a black plug with a blue and black wire) and ground one and test the other with 12 volts directly from the car's battery. Since it's a reverse polarity motor simply switch the ground and power and see if it works the other way too.
I thought my motor or regulator was crapped out as well since I kept hearing a click too, turns out the wiring somewhere else is screwy, I have yet to figure this part though.Last edited by Heysüß; 06-05-2011, 04:48 PM.09/1989 325i 4 Door
+M30 Swap
+Z3 Steering Rack -
Sounds like it just needs replaced. Does it go down and not up? If jumper'ing it works, I would check the wires in the door jamb.sigpicComment
That's my next step is checking the door jamb, any suggestions?
and yeah, that's what everyone kept telling me since it did the same thing (just a click and whirring sound) I also thought it was either the regulator or the motor, but as soon as I jumped it, it worked as if the motor was brand new. I have a thread in the electrical section that has some troubleshooting I did if you think it'll help at all.09/1989 325i 4 Door
+M30 Swap
+Z3 Steering RackComment
09/1989 325i 4 Door
+M30 Swap
