Brake light issue
    Brake light issue
    Well the issue is there always friggin on!!! I replaced the brake light switch and even tried adjusting it only to find out....its not the brake light switch. My father and I are guessing its a wiring problem, but figured id check in here first. Any links to a wiring schematic, atleast the parts relevant to my brake lights??? Oh and my e30 is a 90 325i.
    you can download the manual at www.wedophones.com
    Closing SOON!
    Thanks for 10 years of fun!
      Originally posted by EtheelLambert
      When the running lights are on, alone 1 out of the 2 appropriate active lamps light up. When you abase the anchor pedal, with the active lights on, neither anchor lamps appear on. When you brake out the active lights on, neither appropriate anchor lamps work.
      Did you run something through google translate?
      Ma che cazzo state dicendo? :|
