Need new auxillary fan for my a/c, stick with stock or spal or?
  • clydesdale
    • 631
    I need to replace my fan. It occassionally gets stuck and the bearings are making some noise. This is the electric auxillary fan that is in front of the condensor. Should I just put in stock or is there a better option that bolts right up or with little effort? Thanks.
  • immajackuup
    • Dec 2010
    • 1132
    16inch pusher curve spal fan
    e36 colder temp switch
    hook up to oem aux harness
    • clydesdale
      • 631
      Thanks. Can I trouble you for a little more info? Why do I need the 366 colder temp switch and do I still need to buy the wiring kit for the spal? Do I use the factory fan resistor? Thanks.
      • clydesdale
        • 631
        Has anyone mounted their spal fan to the condenser as a simple stock replacement?
        • immajackuup
          • Dec 2010
          • 1132
          you got pm
