Good day,
i just purchased it with 65000 original mile was owned by 2 people. The first PO sold it to the second one whole kept it for a month then wanted a Auto so i bought it.
He stated that the ICV was bad so he had it unhooked the car would idle at 500 rpm i hooked it up no change i bought a new one and it the car went to 2k rpm and stayed i was like what the hell. What could this bee? also is it hooked up right which way should the arrow face.?
Second issue the heat doesn't work i tried to bleed the system but no coolant came out. There are two sensors on the thermostat housing one towards the front and one towards the rear ones a two pin the other has a one pin the one pin looks like crap what does it do?
third issue on the below picture of the intake system there is a small black box with a electrical connection under it but its not connected and i don't see a wires to connect it. what is this thing?
fourth issues what is the see through box next to the fuse box it has two wires coming from the fuse box wiring harness.
posted are pictures of the referenced issues
