I was wondering if anyone might have any insight into what might be causing this problem. I just completed a head swap after my timing belt broke, and replaced a lot of the stuff along the way. Just finished it today, and the car started up right away and was running fine.
After driving for about 20 minutes I started running into problems. The car idles fine when in neutral or park (it's an auto), but as soon as it is put into any gear (drive, reverse, 1, 2) the idle gets really rough and unless you give it gas to start going right away it dies. It does seem to be driving normal when giving it gas or driving at speed. If I'm driving and get to a red light and stop, I have to put the car into park or else it the RPMs start spiking and the car like tries to lunges then dies right after.
After it dies it takes a couple attempts to start again. I can leave the car and park and start it and it will idle fine for 10 minutes, I can then turn it off and start it again and it starts beautifully. It's just after it dies it doesn't want to start.
Basically I'm just trying to figure out where to start looking for problems with this. Thanks for reading!
