So I'm in the process of finally adjusting my valves but I'm not sure where the cam lobe should be in relation to the valve being depressed to make the changes to each. That is to say should the highest point on the cam lobe (where its at the apex of the rounded triangular part) be where I should stop and then make the adjustment to each valve?
I drew a sketch to show you guys what I mean:
So when that rounded part (cam lobe) hit and pushed the rocker arm and forces the valve eccentric is when I should make the adjustment to each respect valve right? This is also when the valve is open right?
...Sorry if that picture sucks I'm learning all this as I go. Gotta get my feet wet but don't wanna fuck up! Thanks guys
