I've noticed the past couple of times I started my car, there will be a slight squealing for a few seconds and then it's fine. This morning I parked on a hill and was going to 'roll' my car down to it's usual spot. I had it in neutral, e-brake off but the car started off really slow with some definite friction, it gained a little speed and I pulled up the ebrake and got a loud squeal from seemingly the rear(this could be unrelated since they are 2 diff braking systems) I started the car and pulled off, with some slight resistance, the car was fine after turning the corner(5-10 seconds)
Caliper going bad? BTW I had just had all 4 pads and rotors replaced in the past 4 months with a brake fluid flush
