Instrument Cluster Light Bulb Part Numbers
  • PanamaE30
    • Oct 2004
    • 768
    So, I need to replace some bulbs on my instrument cluster. naturally I went to the realoem catalogue to pull them up, but unfortunately the diagram is of no help.
    Basically, i need one turning signal bulb, the bulb for the check engine, and several of the small ones at the bottom for ABS, pad wear, etc.
    Can anyone help me out?
    The part numbers I've got written down are as follows:
    62 11 1 375 774
    07 11 9 978 372
    But I don't know which is which!
    Also, is there anything else that's easily replaceable i outta do while I'm back there?
    1988 325iC - "Betty" - Daily Driver/Project Car.
    1993 318i - "The Golden Dream" - Dad's Car.
    1995 318ti - "Hellrot" - R.I.P.
  • cheades
    • 632
    I have a bunch I can send you, Paypal me like $7 and I will ship you a dozen.
    • Nathan
      • Apr 2004
      • 671
      They are just a genaric bulb, or are you missing the bases to the lights too? If not you can just go to pretty much any general store to pick up the lights. Just bring one in to compare.
      PNW E30 CREW ///
      • PanamaE30
        • Oct 2004
        • 768
        Honestly, I've yet to yank out the cluster. I know the bulbs are either dead or not there because, well, i put the ignition on and I don't see them :P
        If the plugs aren't there, I can get em, the ETK only lists 1, i'm sure that's it.
        cheades: If I did that I'd end up paying about $20 in shipping, so, uh, stealer it is :P
