OK, what am I doing wrong with the thermostat o-ring?
  • clydesdale
    • 631
    The o-ring type gasket is split, I figured the outer edge of the thermostat fits into this. But, the thermostat alone is a perfect fit. How do I get this big o-ring to fit inside the housing? What am I doing wrong?
    • 37829
    It goes thermostat then oring.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • CHIF8008
      • 3447
      hahaha
      -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
      -The Beauty in the Tragedy-
      MECHANIC SMASH!!- (you all know you do it)
      Got Drop?? ;-)
      But of course
      E30s are know to be notoriously really really really ridiculously good looking
      • clydesdale
        • 631
        Are you sure? I called bavauto, told them what I was doing and they said it is correct. Obviously, they could be wrong. This o-ring is not the typical solid looking "o-ring". It has a slit all the way around it and the thermostat is able to go inside this slit, so that some of the o-ring is behind the t-stat and some in front. Imagine a thick o-ring with a slit all around it and the t-stat seems to appear to fit into that slit. Why else would they have the slit?
        • CHIF8008
          • 3447
          never seen it like that for a e30. maybe put the o-ring in first- and then get the lip of the thermostat in the slit. its usually done as MR 325 said
          (your saying the thermostat sits in the o-ring?)
          Got Drop?? ;-)
          But of course
          • clydesdale
            • 631
            It does appear that the t-stat sits in the o-ring. I am going to try putting the o-ring in first and then use some tools to slip the o-ring around the t-stat. This o-ring is thick and has a slit in it all the way around.
            • kronus
              • Apr 2008
              • 13032
              I think you got an incorrect o-ring. All the T-stat kits I've gotten have o-rings with a square profile that go between the thermostat and the t-stat housing cap.
              cars beep boop
              • clydesdale
                • 631
                This does have a square profile. It is not rounded and smooth. Maybe it is just the way the mold is? When I removed the original, it came out in 2 pieces, as if the slit went all the way through. It was like I removed to halves of the o-ring. I just can't remember if half was in front and half behind. I figured this would be straight forward and did not pay that close attention. I did find it odd that the o-ring came out in 2 identical pieces.
                  The seal should be between the thermostat and the thermostat housing cap.
                  • clydesdale
                    • 631
                    jlevie,
                    If that is the case, then the stat does not go in the slit. You may be right. I will take a look tomorrow. Have you ever seen an o-ring that is sort of 2 pieces like this?
                    • Todd Black 88
                      • Oct 2007
                      • 3449
                      Yes.
                      I had a ford escort gt at one point, and it had a gasket just like what you are refering too. The t-stat actually fit in the gasket so there was a seal on both sides.
                      Never seen it like that on an e30 though.
                      Originally posted by codyep3
                      I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
                      2001 silver/Blk 325 cabby. SOLD
                      2002 325xit Sil/blk. SOLD
                      2010 F650gs twin
                        • 37829
                        Grover Beach, CA
                        www.BimmerHeads.com
                        • clydesdale
                          • 631
                          Well, the gasket I pulled out, came out in 2 identical halves, as if it was just like what I have now, but it split into two. So, maybe the gasket it designed to go as MR 325 has stated, but it is the odd type of o-ring. I will probably call bavauto tomorrow and have them pull another off the shelf and check. But, it sounds like I should put the t-stat in, against the housing and then put the o-ring and then the cover. Correct?
                            • 37829
                            Yes, you are correct. It should not be an "weird gasket" either. It uses a pretty standard looking o ring.
                            Grover Beach, CA
                            www.BimmerHeads.com
                            • clydesdale
                              • 631
                              Yep, wrong damn gasket. I went to the Advance and I can't believe they actually had a Felpro 0-ring for a t-stat for our cars. It fits like it should. I will chuck the other one before I make a mistake and attempt to use it some years later. Thanks guys.
