r12 a/c for 318is
    r12 a/c for 318is
    What are the common place for freon to leak out??
    Is the green o-ring seal compatible with r12??
    Where can I buy r12 freon dye??
    Lookup Duracool / HC-12a. Works as well as R12 (and it's old system friendly) and it's not bad for the environment.
    Ich gehöre nicht zur Baader-Meinhof Gruppe
    Originally posted by Top Gear
    Just imagine waking up and remembering you're Mexican.
    Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
      you is crazy
        The compressor shaft seal behind the compressor clutch, a hole in the condenser caused by flying debris coming through the grill, the crimps at the ends of your flexible lines, the o-rings underneath the manifold where the flexible lines come out of the compressor....
        Yes.
        Don't put dye in your system, it's a contaminant. Use pressurized dry nitrogen and soap bubbles to find leaks.
        As I have posted before, a perfect refrigerant for recharging r12 systems is r414b. It is an r12 drop in, which means that it will run similar pressures and is compatible with your compressor, compressor oil, expansion valve, and pressure switch. I just recharged both of my neighbor's cars (both 80's era Fords) using r414b with excellent results (45-50 degree vent temps. @ 90 degrees ambient).
          you is crazy
          Yellow journalism at it's best.
          God forbid you have a gasoline leak in your car...
          Or an explosive sitting 8" from your face...
            Yes.
            R-414B is really expensive comparing to r12 freon. why not use regular 12 freon??
              Because you can't buy it anymore...
                oh yes i can lol
                  Propane and butane are highly flamible gasses. They won't spontaneously combust in a system, but I'd be worried about it in a wreck... or if your evaporator leaks.
                  Originally posted by Gruelius
                    If your car is leaking that much refrigerant, you won't have AC for long. Cars don't hold much refrigerant to start with.
                    FYI it is approved for use by the Canadian DOT (whatever it's called), so it can't be that bad. I've also been running it for the last five years, and I'm still here. Now about that time I had a fuel line rupture...
                      99.9% of the r12 you see for sale is recovered r12. Unless the people responsible for recovery were meticulous and the systems they recovered the gas from were clean you risk introducing contaminants into your system.
                        Lolz
                        Parts Wanted
                        The Never-ending Resto Mod
                          just bought this for 16 a can.
