Whats the word on cluster swaps. I have a 1984 318i, can I swap clusters with a 1991 318i?
Cluster swap
I don't have any definitive answers on yours (there are physical differences between the units). BUT, I'm currently using a cluster from a 87 325e, with a speedometer and fuel gauge from a 91 318is and the temp gauge from a 1984 325e. As a whole the clusters are interchangeable, and internal parts the differences I saw were between the tach's, SI boards, and fuel gauges. Late model 325's had different tanks.
TLDR: try it, i dont suspect you'll have any problems.1990 332i, 4 door
2008 KTM 990 Superduke
2018 Golf R, 6spd manual (Pending delivery)
2017 Mazda CX-5 GT
2007 Z4M Coupe - Sold to very nice people -
The late cars have radically different fuel level values, they are not interchangeable, but AFAIK, you can simply swap the gauge form the '84 cluster into your late cluster.
As above, try it.Comment
Ok so I swapped clusters (mines old white back) with a newer blue back unit. Everything works perfectly, except the fuel gauge as stated above. I even took the speedo from the new unit and put it in my old unit, works perfectly!______________________________________
1984 LSB 318i - Sold
1986 325i - Motor Swapped Track Car Project
1995 318ti - Sold
1999 540iA - Daily DriverComment
