goofey idle w/ video
    ok little back story, i got this car with a burnt exhaust valve on cylinder #5, fixed that. car runs great all the time other then the idle, just seems a little too bouncy. the tach doesn't move at all but it just feels like a slight miss when in gear sitting at a light.
    so here is a video i just took of the car. the only issue that i need to address is the oil pan leaks. now i know this is a sealed PCV system so that in theory then if the pan is leaking it can be a vacuum leak.
    one thing i did notice is when you sit and rev it about 4K or so it does spit out a little black smoke so i know its running a little rich but i pulled the plugs and they look perfect.
    Originally posted by nwvb bmw
    That guy is going to lock you in his basement and make you ware a little pirate costume.
    No one?
      anyone? since i have now done a 5spd swap on the car i changed up my exhaust setup. well now i go out in the morning and fire the car up before work it will leave a black soot mark on my drive way while idling.
      so i know its running rich, plugs look ok other then a little oil on them (burning a little at high RPMS's)
      car is bone stock for mods, stock chip, etc. 214K, rebuilt top end, 5spd swap, thats it.
