Can I convert r12 plug to r134a and still use r12 freon?????? As of of why I ask because I don't to waste money on getting a r12 gauge.
convert r12 to r134 plug
Tags: None
just bought 12 cans of r12 for 16 each and all I'm asking is can i change the r12 port to r134a and still put r12 back in through a r134a gauge???Comment
Depends. Anyway, if you were paying attention that's not the OP's intention.
The e30 HVAC system was designed to use r12. Pressures will be appropriate for system components. Head pressure will be lower as will vent temps.Comment
I'll put money on it that you have 12 cans of counterfeit r12 that could be filled with anything from duracool, to r134a or propane/isobutane.
You can use r134 conversion service ports to use with your gauges but a set of r12 hoses is usually only $20 or so but if you don't know that the refrigerant your charging with is genuine and uncontaminated then your pressures could be all over the map and you won't be able to properly charge or diagnose the system in the future. ;)
