ditching my clutch fan...
  • 85e325
    • May 2011
    • 551
    after a several hour battle trying to remove my seezed fan clutch(which won) i have decided to install a electric fan. I was just wondering if anybody has taken on this project and there recommendations are. What i had in mind was to delete the a/c and install a large diameter pushing fan to the front side of the rad where the condenser would be thus giving me more room in the engine bay.
    Justin Angelli
    1985 325e Gazellenbiege
  • Bearmw
    • 1323
    Recommendation: SEARCH FUNCTION
      That can be done, but you will need an 82-83C thermo switch, additional relay, custom fan brackets & shroud and at least an 16" 1800CFM fan (a 16" 2300CFAM fan in warmer climates). The overall cost of this will be greater than a fan, clutch, and waterpump.
      If the fan nut is trully seized on the water pump shaft such that it can't be removed with a counterhold tool, the entire wanter pump and fan can be removed as a unit and a new water pump and fan cluth installed. Keep in mind that the fan nut is a left hand thread.
      • Jaxx_
        • Dec 2009
        • 1880
        with 74 posts you seem to lack the ability to have content in your posts. what happens when the next person searches for clutch fan delete?
        I removed my clutch fan in my M10, the real reason was to remove parasitic power, PS/AC also removed, nor to gain more room in the engine bay(lol m10)
        Instead of fabbing a bracket or anything new, I cut out the condenser coil from it's bracket and used the factory aux fan mount. the aux fan is controlled through megasquirt and only turns on when the motor hits 190F, and turns off after the motor reaches 175F. My thermostat is fully open at 160 iirc.
        Here's the bracket with the coil removed. lots of air escapes on the sides, but it cools off the motor, even in this horrible NC heat(centuries... 100F+) after autocross runs and sitting in traffic.
        • 85e325
          • May 2011
          • 551
          you make a strong point but with goal of doing a v8 swap in the future the extra clearence would make things easier. I was also thinking about using the orginal shroud and modifing it to work with the electric fan.
          Justin Angelli
          • Bearmw
            • 1323
            Quote:
            "with 74 posts you seem to lack the ability to have content in your posts. what happens when the next person searches for clutch fan delete?"
            I guess the value of our response is determined by the number of posts? And thank you for reading all of my posts BTW.
            I have gotten useful info from this site long before I began posting and one of the most useful things I have discovered is that it is generally best to research the topic through previous postings and stickys prior to asking certain questions. Often I found my question was already asked and answered. After searching I was then able to ask a more specific detailed question which I imagine was easier to respond to. Take my advice with a grain of salt.
            It is a harsh world for all of us (me to);)
            • bmwm42
              • 6300
              I mounted my aux fan to the shroud I have to electric fans the one for the ac and one for the engine
              Originally posted by bmwm42
              PNW vulture pm me for parts
              Strategic nw e30 command
              • Jaxx_
                • Dec 2009
                • 1880
                yeah, hence the reason people who have more posts know more. ;) the point was why post if your contribution is simply to say search? It doesn't help anyone. You should at least help them by searching and posting your results. It helps now, and for future searchers.
                To the op: if more room is the goal, redo the assembly and go with a slim spal fan. My solution is pretty much free, but it's not a permanent solution for something that you're suggesting. And when i go turbo you'd better believe that's not going to be my cooling setup. I don't even know if my bandaid solution could even cool a m20.
                • Jean
                  • 18228
                  Lol nice! There are actually OEM brackets that you can still buy to mount the stock fan in the stock location W/O the AC core ;) IIRC they were about $10 for the pair.
                  • Jaxx_
                    • Dec 2009
                    • 1880
                    haha that would be awesome, do you have the part #s? lol
                    • Bearmw
                      • 1323
                      Bimmerworld sells some Spal fan mounting brackets, fan sealing gasket (to prevent air flow loss out the sides) which I like, and a fan controller. I think Miller performance may also sell some decent fan stuff but I don't know the details. Massive sells some brackets as well. I guess the best setup for you will depend on your specific cooling needs and budget. For my M30 I went with a big Spal pusher, their brackets, the seal, and just wired into my existing wiring without an aftermarket controller. I also am using the stock temperature thermostat. Spal is mounted directly on the E28 radiator but that will have to change if I reinstall the AC.
