Found a fix for my WOT stutter
  • Fodofosho
    • Jul 2011
    • 61
    For all of you fighting a stutter at WOT, check your fusible link. Mine was all corroded so I threw a new one in and now it drives like a dream. Thought I'd help if I could. happy motoring
  • E30MACK
    • Dec 2009
    • 230
    fusible link? where is it?
    • accident
      • 7303
      In the trunk, it's inline with the battery cable.
      Moral of this story?
      • BergerNJ
        • Oct 2009
        • 349
        where would it be if my verts PO relocated my battery to the front?
        • accident
          • 7303
          I'm not sure where it is on the front mounted batteries. However, it wasn't relocated. The very early (84-85) 318s and all of the convertibles have them in the front.
          • e30trooper
            • 11576
            whats it look like greg, my car is broke ... i need to check everything kthnx
            • accident
              • 7303
              it's on the secondary wire on the positive terminal. it looks like a little flat piece in the middle of the wire, at least in the rear battery cars
              • e30trooper
                • 11576
                would my car still crank even if the fusible link took a shit?
                • dreamchasin
                  • 3890
                  My buddy removed that wire out of my car, and it ran "ok", still chirped 2nd and 3rd (NV m50) and today (which is a day after i got it from putting the suspension/wheels/interior pretty much everything together) i went to start it to go to work and it sputters like crazy and barely moves. idles like it's running on 3 cylinders.
                  90 325is alpine2 m50b25 becoming a dorifto car.
                    Yes. That wire (and fusible link) supplies power only to the engine management system. The starter is powered from the large cable.
                    The best fix I have found for the fusible link is to cut out the link and splice the users, using a solder connection. Then where that wire connects at the power point in the engine bay use a lug type 60a fuse between the wire and the power point.
                    • e30trooper
                      • 11576
                      thanks, any idea where this would be on a vert?
