I had a radiator hose come loose on the Palisades Parkway in Alpine, NJ this afternoon in my M50'd 318is. Car was overheating so I pulled over, got the hose re-attached with a new clamp, let it cool down, and then filled the car up with coolant. Now it continues to overheat and I am not getting any cabin heat. I had some bubbles in the expansion tank and was afraid it was a head gasket failure, but the car was only gently driven for a minute or two after the coolant temp started rising on the highway until I could exit off the highway (no shoulder). I am hoping the bubbles were just trapped air in the cooling system escaping.
With all that said, I think the problem is a stuck thermostat.
Maybe there is just still air stuck in the system? I am not really sure if I was bleeding the system correctly...I ran it with the cabin heat on full hot for a while, with the expansion tank cap off and kept adding coolant...but my temp needle kept going up. What does this sound like the problem is? T-stat?
