Hello R3v,
I am still new around here but not new to forums cars etc ( still waiting to do a formal introduction ).
So after lots of searching and reading ( which has guided me in the right direction ) im still a little unsure what went wrong.
Car - 89 325is
Battery was dead ( cars been sitting for a bit ) I jump started it and it jumped right up and I let it warm up. Drove a block it stalled and now will not start..
So after much searching I found to check for a bad fuel or main relay. So first I check the main relay :
I turn this whole cluster upside down and try probing the biggest of the middle 3 wires ( I probed everyone with the key on or off ) nothing has power via my test light.
Even tried bypassing the relay but i figured with no power that also doesnt matter ( jumped 87a 87b 30 ) 3 middle wires. NADA
The battery is dead but I have jumper cables on the car, It cranks but nada. I didn't check for spark cause I figured if the main relay doesn't have power I have a bigger problem to fix first.
Could this be crank position sensor? or something else?
Any help would be greatly appreciated as I keep searching and testing.
Thanks,
Car - 89 325is
Thanks,
