I have all the bolts out i think. there doesnt look to be any more but the pan is still stuck towards the back where it connects to something else. What am i missing?!
It's stuck to the tranny Lower support. There are four 13mm bolts that bolt it to the Engine block then a couple torx bolts that go threw the tranny into it. Once this is removed you'll see 6 or so more of those 10mm bolts to pull off then the pan should drop right off.
My pass side motor mount is broken...i tryed to ubolt the nut like 20 min and it never moved..my dad said it must be stripped...so i got the lift real close and jacked it up and the thing wasn't even attached. Only the drivers side mount was...scary.
