Talking bout diff...How to tell the ratio
  • bwanac
    • 3354
    I dont know if this is possible, but i have found a parts car i may buy with a lsd. the thing is the tag on it is to hard to read, completely worn away. is there a way to see what the ratio on the thing is? is it written somewhere else, or some way to do it physically?
    Thanks guys
    and this will be my new home from now on i guess. :up:
  • MattE30
    • 1520
    To tell the ratio, jack up the car so the ass is up in the air. Spin a rear wheel. If the driveshaft spins a little less than 4 times per wheel roation, you have a 3.73 diff. If it spins a little more than 4 per 1 roation of the wheel, you have a 4.10 diff.
    97 Cosmos M3
    • Super-Eta
      • 53
      What kind of car?
      • Jordan
        • 12907
        What year and model is it (be sure to say 5spd or auto) and I can tell you what diff it should have.
        https://mtechniqueabs.com/
        • Jand3rson
          • 37587
          Try FOOL-PROOF method. (Not to downplay Jordan)
          - Jack the car up from the rear and get under it on your back. And bring a wire brush with you, you're going to have to clean 15 years of road grime off your diff to see it.
          - Attached to one of the bolts on the bottom rear of the diff, I believe it's on the right, there is a small metal tag. This is your diff ratio.
          - If there is an "S" before the number, it's a limited slip. If not, and there is just a number, it's an open diff.
          - Mr. Anderson
          • Jordan
            • 12907
            Re: Talking bout diff...How to tell the ratio
            Originally posted by bwanac
            thing is the tag on it is to hard to read, completely worn away.:
            Ahem.. josh.
            READ before you post.
            • UNHCLL
              • 8789
              Ahem.. josh.
              Should we make that a requirement for membership? Literacy? ;)
              Below the radar...
              • bwanac
                • 3354
                ok.
                it is an 87 325. so it is just a basic eta, the story goes like this
                i called the towing company that has it. they got it for free bc after they did some work on it for some guy, he was no longer reachable. so all he knows is that it is posi traction. the tag is unreadable, and it is a 5spd. i dont know if it was special factory ordered or "aftermarket". but from what everyone wrote above i will try that method.
                • decay
                  • 5637
                  isn't there also a 3.91 rear? supposedly this is what showed up at my door last week.
                  past:
                  1989 325is (learner shitbox)
                  1986 325e (turbo dorito)
                  1991 318ic (5-lug ITB)
                  1985 323i baur
                  current:
