C101
  • M20bmw318i
    • Aug 2005
    • 20
    C101
    Not getting any spark form the coil, the coil is good tested it in another car. does this look right for swapping any 90 M20b25 motor into an 84 318i. i think i have the wiring fucked up so where
    318i Chassis -318i Engine- 325i Chassis-325i Engine- Function for 325i
    White/blue -White/blue- White/blue- White/green
    violett/green- Blue/White- Violet/green- Blue
    Black/brown-Brown/green- Black/brown Brown/green
    Violet/red- Green/violett(lg)- Violet/red(large guage)- Green/violet(S&L guage)
    2(sg) blue- Blue- Blue- white
    Blue/yellow- Blue/violet Blue/yellow- black/white
    Green/yellow-Green/yellow(lg)- Green/yellow(LG)- Green/white
    Green(lg)- Green(lg)- Green(lg)- Green(Lg)
    Black/yellow(S&L guage)- Black/yellow-black/yellow-Black/yellow
    Yellow/white-White/black- Fuel rate output
    Black- Black- Engine speed output
    Brown/black-Gray- Check engine light
    Blue/black- Green/yellow
    White/black- White/black
    Red/yellow(sg)
    Brown/violett- Brown/violet-Brown/violett-Brown/violett
    thanks for the help
  • uflnuceng
    • Apr 2005
    • 1049
    I think you need to ellaborate a bit... are you having a coil problem with your M10 and going to put an M20 in instead?
    I'm not sure about the wiring thing... Bentley should have that figured out but I don't have that book with me at the moment.
    • M20bmw318i
      • Aug 2005
      • 20
      C101
      I HAVE AN 84 318I AND I PUT A MOTOR OUT OF A 90 325I THAT I HAD WRECKED, I AM NOT GETTING SPARK FORM THE COIL OR AN INJECTOR PLUSE. I THINKS ITS IN THE WIRING, NOT HAVING A GROUND OR MISSING AN HOT WIRE SOMEWHERE DOWN THE LINE.
      • ryan_george
        • Mar 2004
        • 331
        I had pretty much the exact same problem when I went from an ETA to the "i" engine. No fuel, no spark.
        It was eventually diagnosed to be a problem with the OBC "disable" option. My car didn't originally have the 13 button OBC, so I swapped it in with the new engine. I was missing part of it, and this pretty much told the ECU that I was trying to "steal" the car, and it shut off the fuel and spark.
        Have a look into this, hope it helps.
        -Ryan
