Coolant exploaded near my pedals during emission test?
  • El Gato Liso
    • Jun 2008
    • 44
    Hi
    I was doing an e-test and boom coolant blows the F up inside my car.
    I did some research...the heater core may have taken a shit. But i also read the heater core valve may have failed too....
    i am not sure which one it is, but my carpet is drenched in coolant.
    My fan doesn't work at all *the dials 1 2 3 and 4* i replaced the resistor and i still have nothing working.
    any ideas?
    thanks
    -rob
    The most likely failure is of the core, though a failed seal at the valve is a possibility.
    The blower fault could be a fuse, switch, or blower motor. A few minutes of work with a test light will tell where the problem is.
    • Simon S
      • Oct 2004
      • 3758
      Ouch – sorry to hear..
      Fwiw, it’s my understanding that it’d be a good idea to replace the core, the valve, and internal piping if just one of them failed..
      Hopefully, you’ve got a late model which I’ve read is much easier to access/service.
      Can’t be of much help with the fan.. if it went out at the same time as the leak – I’d suspect the valve to have something to do with it (?)..
      -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
      • El Gato Liso
        • Jun 2008
        • 44
        well the dials slowly stopped working till 4 only worked, then i did hear birds chirp from the vents.
        anyway, i suppose i should just replace it all. i have a 1990 m50 swapped.
        all the fuses are fine...perhaps the blower motor itself is roasted?
        i will rip out the core tmrw, and diagnose the problem. my car was passing emissions with 4 seconds left till it exploaded...lol
        thx for the help guys!
        • Simon S
          • Oct 2004
          • 3758
          Yeah - the chirping is a good indicator that the blower motor was on its way out..
          Ah, cool - glad to hear you've got a late model to work with. Early ones are [even more of] a nightmare from what I've gathered.
          Dude - I do not envy you - hang in there. Cringing at the thought of all the parts added up together..
          lol/bummer about the timing. =-)
          A late model, m50 swapped car is worth keeping healthy !
