On the way back from Bimmerfest East my AC stopped working (just replaced everything last year). On inspection, the clutch at the front of the compressor is shredded so I assume it has failed. Rather than go through the headache of replacing just the clutch I am replacing the compressor.
Here's the question: When I drain the system and swap out the compressor, do I need to replace the receiver/dryer again before charging?
I have read that it has to be replaced each time you open the system.
Thanks in advance.
Thanks in advance.
