smt6 purchase?
  • NC325iC
    • Mar 2004
    • 6565
    smt6 purchase?
    where can i buy an smt6 cheapest? and what all do i need, at the moment the setup is a 3.0l stroked with i believe 19#ers (orange body if that means anything) and a 733i AFM
  • M20bmw318i
    • Aug 2005
    • 20
    E-mail this web site and ask them if they have a smt6 that will work with ur combo.
    info@perfectpower.com
    this is the only web site i kno that sells the smt6 http://www.perfectpower.com/default.asp
    sorry this is all i have
    • NC325iC
      • Mar 2004
      • 6565
      anyone else?, also where can i get a matching afr guage?
      one more question, which way do you turn the afr screw to make it leaner?
      • UNHCLL
        • 8789
        SMT6 is not a chip.
        It is not a "plug & play" for my engine combo type of device
        Learn what it is you THINK you want to buy BEFORE you even consider buying it.
        The fact you dont even realize/comprehend/understand how the SMT setup works tells me you shouldnt be buying it yet.
        good luck.
        Below the radar...
        • Jordan
          • 12907
          His parents bought him a completely built 3.0l engine. He doesn't have to know anything.
          https://mtechniqueabs.com/
          • Bryson
            • 1490
            I'll sell you one for 350 shipped. It was connected using the bypass so it has never been used electronically
            • NC325iC
              • Mar 2004
              • 6565
              i know that its not a chip jackass. yes my parents bought it for me, im sorry i dont have enough money to buy it myself or enough skill to build it myself, im sorry im not as good as you are oh holy one.
              smt-6 is a piggy back system used to alter the signals coming out of the ecu to better tune for upgraded engines, changes fuel maps, and ignition maps etc however needed. if this is completely wrong than i guess you all are right and i should be shot. if anyone can give me some help in finding one, or what i need if i was wrong, i would be very greatful, if you just wanna give me shit or call me spoiled or something like that i dont really want to hear it so keep it to yourself.
              thanks
              • NC325iC
                • Mar 2004
                • 6565
                oh and by the way UNH i am not just gonna get it and change shit on it randomly, im going to take it to be tuned on a dyno, by someone who knows what theyre doing.
                • UNHCLL
                  • 8789
                  Throw money at it, that always fixes it.
                  Good, you can read and re-type what is on the Perfect Power website.
                  You now deserve to install an SMT6!
                  You can buy Brysons, or from Perfect Power, or From GSTunning
                  Afterall, its only money, and given what dyno tuning will cost, why worry about the measly $50 difference in price? ;)
                  Below the radar...
                  • cthulu703
                    • Oct 2004
                    • 288
                    You clearly do not have a chip on your shoulder.
                    • NC325iC
                      • Mar 2004
                      • 6565
                      all past talk aside what would you reccomend i do... i admit to not knowing much about these things... it has been advised to me that i get it tuned soon because the injectors could be putting too much fuel in and washing the oil off the cylinder walls. this is something i was told by the man that built the engine. is there anything else i should look in to. i would like to focus more on getting the engine running right than how i got the engine.
                      thanks to anyone who give me anyhelp.
                      i would like to get it tuned so i can get the best power out of it. if you can think of a better way to do it let me know.
                      • Charlie
                        kid tested, administrator approved
                        • 6686
                        Ask your local shops what they have experience tuning with. Probably doesn't do much good if a shop has never seen an SMT6 and you ask them to set it up for you.
                        -Charlie
                        Swing wild, brake later, don't apologize.
                        '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
                        FYYFF
                        • UNHCLL
                          • 8789
                          Actually I dont at all. I just find humor in mocking ignorance.
                          NC325iC-
                          SMT6 is probably your best bet.
                          If you have any hesitation at all with installing it, I'd advise you not to even try, no matter how tempting. Take it to a professional and have them do it. It will cost a pretty penny for the install & tuning, but it will be well worth it in the long run. Investing in a Wide Band O2 sensor would be a good idea if you ever plan on modifying the engine setup again later on.
                          Try and find someone who is familiar with the SMT setup, it will make the cost of tuning it less... less time for them to fuck around learning it.
                          HTH
                          Below the radar...
                          • trent
                            IGNORWHAAAA?
                            • NC325iC
                              • Mar 2004
                              • 6565
                              well the install all depends on if i can get the wiring setup from bryson as well, i dont really have much problem doing it myself. and i have been searching for shops familiar with it and i believe i found one down in Winston Salem. if you had seen my other post you would have known that id asked people.
                              thanks for the help.
