Subframe removal Help!
  • Massimo
    • Jan 2008
    • 3207
    Hi Guys
    I am trying to remove my subframe and am now a bit stuck. So far I have removed the shocks disconnected the brakes and hand brakes, the diff bush bolt subframe bolts and that sensor on the diif, also the drive shaft to diff connection. Now I can lower the assembaly no problems but I can't for the life of me figure out how to disconnect the drive shaft with out removing it.
    I have one Idea, that is to unbolt the center support bearing on the drive shaft then lower the subframe. That way it will bend at the uni joints then once I get it low enough I can simply slide it back and hang the drive shaft from the body some how. Would this be ok.
    I have seen pictures of people hitting out the subframe bush bolt, my problem is that that hole under the back seat is sealed with some kind of rubber so I can't get the bolt out.
    Please help.
    Cheers.
    • 37833
    You need to remove the driveshaft.
    Grover Beach, California
    BimmerHeads.com
    • robmespeedy
      • Oct 2004
      • 561
      Loosen up the heat shield in the rear. this will let the drive shaft lower more.
      then youll just have to play with it.
      • drumad
        • Aug 2009
        • 1700
        You gotta pick that tan/brown rubber stuff outta the hole. Then you can wallop those bolts out.
        2008 335i - n54b30
        1991 318i - m52b28
        1994 fzj80 - LAND CRUSHER
        • nrubenstein
          • 3148
          Just wallop the bolts out. The goop will form a cylinder on the bolt head.
          2002 BMW M3 Alpinweiß/Black
          1999 323i GTS2 Alpinweiß
          1995 M3 Dakargelb/Black
          - S50B32/S6S420G/3.91
          1990 325is Brilliantrot/Tan
          1989 M3 Alpinweiß/Black
