rear wheel bearing
  • jrobie79
    • Mar 2006
    • 2526
    rear wheel bearing
    I just installed new rear wheel bearings, and pressed the hub into the bearing, however there seems to be some play in the hub, both in and out as well as 12-6, 9-3 movement....its not that much but it doesnt seem like thats normal... I feel like they came out of the box like that as well....any suggestions or insight?
    1991 318i ---- 308K - retired
    There will be play in the bearing until the axle is installed and the axle nut brought to full torque. If you haven't yet installed the axle what you are seeing is normal.
    • bmwmech1
      • Jun 2010
      • 1075
      Yup, I just posted the same answer to your thread on the tech...
      Garey
      • jrobie79
        • Mar 2006
        • 2526
        that was my first guess too, about not having the axle in......thanks guys!
