Removing Glovebox with Broken Handle
  • NickAlero
    • Jul 2011
    • 98
    I'm sure someone has to have gone through this before. Is there a best way to go about this, or is the whole box done once the handle is broken? Any screws, nuts, bolts, etc?
    Thanks in advance for any help!
  • ethrtyiS
    • 8147
    get underneath it and unbolt it. then tear it off. use a flat head.
    「'89 BMW 325is | '02 Mitsubishi Montero Limited | '2005 GMC Sierra 2500 Duramax | 2007 BMW M5 」
    「my feedback thread」
    • Hey_You
      • Nov 2009
      • 963
      You can get to the latch, not sure exactly how, but one of the techs was able to get mine open with the handle broken. I then replaced the handle before I closed my glovebox again, haha
      85' 318i ~The Bronze Bomber (FrankenM10 with a Forced Future :wgaf:)
      • ScHpAnKy
        • 1573
        wondering the same, I as of yet have no idea what's in my 325e's glovebox haha
        91 318i | 87 535iS
        • ethrtyiS
          • 8147
          iirc, i was able to use pliers and a flat head to still utilize what was left over after the latch had broken off. just take a close look at it. if that doesn't work, unbolt from rear and rip it off, you can always get another from a yard.
          • Jaxx_
            • Dec 2009
            • 1880
            i removed the hinge on the back of the glove box. a little bit of back pain but I think it's 3 10mm bolts that hold it on. IIRC you'll still have to rip it to pieces.
