stuck wheel bolt- not broken YET
  • clydesdale
    • 631
    I broke one on the other side a few weeks ago. I had to drill it and use a tap to cut out the rest. I want to avoid that process. Any suggestions on a method to remove this without breaking it? I have a cheap harbor freight impact gun that will go to about 260ft/lb. The last one I broke just using a regular socket set. I did lean into it pretty damn hard. I don't want to snap this one too. Thanks.
  • bmwm42
    • 6300
    pb blaster and breaker bar use your foot to push down on it
    Originally posted by bmwm42
    PNW vulture pm me for parts
    Strategic nw e30 command
    • kronus
      • Apr 2008
      • 13022
      try a deadblow hammer.
      cars beep boop
      • Simon S
        • Oct 2004
        • 3758
        Shit - if the fucker's frozen good enough - ain't no 'force' technique gonna help.
        (impact, breaker bar, foot, and/or dead blow will all snap it)
        Think in terms of 'un-freezing' it (PB and torch)
        If I were you, I'd:
        1 - apply PB
        2 - heat with propane torch
        3 - repeat 1 & 2 like six times over 1-2 days
        THEN - put the force on it.
        THEN - track down the fucker who over-torqued them and crack his skull open with your lug wrench.
        -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
        • CHIF8008
          • 3447
          hammer on a socket. and i mean hammer it on. then use a breaker bar. that's how i got off my rounder off/ over tightened lug
          -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
          -The Beauty in the Tragedy-
          MECHANIC SMASH!!- (you all know you do it)
          Got Drop?? ;-)
          But of course
          E30s are know to be notoriously really really really ridiculously good looking
          • Simon S
            • Oct 2004
            • 3758
            A point to make with the PB use would be to do the best you can to squirt the lug threads coming out on the back of the brake rotor.
            (the way the lugs are shaped would make PB penetration difficult from the 'front')
            Shit man - good luck.
            • Simon S
              • Oct 2004
              • 3758
              Good point here.
              Impacts on the lug itself would be an 'un-freezing' technique.
              • clydesdale
                • 631
                Thanks for the suggestions. I do not think I can use heat, the wheel is still on the car. I can try to get PB in from the rear. I was wondering if using my little impact gun would help. I thought about setting it to loosen, then tighten, then loosen..... I was hoping that impact would break it free. We shall see. Just hitting it with a breaker bar is sure to snap it.
                • clydesdale
                  • 631
                  I sprayed PB blaster from behind several times over the weekend. I then used a rubber mallet and a breaker bar and shocked it clockwise and counterclockwise several times. Eventually I heard it creak and start to move. It is out and I probably saved 4 hours of drilling, and tapping.
