OK so as most of you know I am wiring an engine in my E30. It is a nissan engine. The starter has 2 posts, one is the thick power wire, the other is the solenoid signal wire. This wire should be live only when they key is in the start position.
According to my 1987 factory service manual (electrical, convertible), the black/yellow wire that goes to the diagnostic plug is the one. IT isn't. it is hot whenever you are in "run" position. I tested every pin on the back of the ignition switch and all of them run 12v in "run", or nothing in start. I am totally lost. Did my ignition switch go bad when I removed my old engine? how is that even possible? it worked when i drove it into the garage.
Any help is appreciated. I don't reallt want to rig the car up on switches and a button.
