Hood latch cable route through engine bay
  • JubJub
    • Feb 2011
    • 256
    My car came without the cable (probably broke) and I'm trying to route a new one. I can't find where it enters the engine bay or the hole where it leaves the cable.
    I know where the mechanism is to unlatch the hood but do I have to remove the headlight or radiator to attach me new cable? After reviewing it, it seems that way.
    Does anyone have pics that would show it? Thanks in advance.
  • bmwguy325is
    • May 2011
    • 1263
    You should be able to replace the latch mechanism buy removing the grill. It slides out to the side or from the side of the little lump it sits inside. The cable runs along the drivers fender and there is a gromet for to go through. Though when you run the cable start from inside the car. Its super easy to see where is goes Ive had to replace three of them.
    sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
    The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
    • CW325
      • Jul 2011
      • 1434
      there should be a hole in the firewall next to the fuse box near the hood latch, i can take a pic if you need it
      • JubJub
        • Feb 2011
        • 256
        got it guys. Thanks for the help!
        • e30sequel
          • Nov 2007
          • 232
          Hi
          I am have this same problem - can you please post some pix of as many parts of the route as possible - it is a very common problem but no one has done pix/diagram etc of this at all (maybe because it is super easy ..) and sticky the biatch once n for all :hitler:
          thanks in advance
