fuel line keep leaking
  • jaydeep
    • Jun 2011
    • 208
    First fuel injector line started leaking now FPR return line started leaking. I want to replace all fuel line. Do you guys know if there is any diagram? I can see there are two line coming from firewall but don't know about bottom of the car to fuel filter.
    Where to get fuel line and how long do I need it?
    sigpicGLETSCHERBLAU METALLIC with leather INDIGO LEDER interior and blue top.
  • TurboJake
    • 3780
    RealOem.com
    Buy a Bentley
    Download the Bentley
    Or just follow them...
    Leave Me Transaction Feedback
    • slammin.e28
      שמע ישראל
      • 12054
      Watch what you get. Get the real BMW line....not the shitty stuff from Autozone.
      • WhatWentWong
        • Jun 2008
        • 265
        anything printed as being compatible with SAE 30R7 is NO GO. that's low pressure stuff.
        anything printed with SAE 30R9 is appropriate as it is rated for fuel injection.
        You are looking for 5/16" ID, about 2m worth.
        • Pantless Spency
          It's McRib time!!!
          • Feb 2011
          • 7283
          Originally posted by TurboJake
          RealOem.com
          :O you're saying i can pirate bentleys? shit i'ma be rich fo life i'll sell em on craigs for 80k a pop! i'll be making scrillaaaaaz, why kind of rendering equipment do you need? 12x20 foot 3d ceramic printer? lol.
          • TurboJake
            • 3780
            Direct metal laser sintered aluminum printer. That ceramic printer is for da weenies y0!
            And SOOOOOOO last week! Who would want a 3d printer that can't print out your very own S82, S14, And/Or S38?
              • 37832
              Yes, buy the overprices OEM line for no reason!
              NO.
              Just buy 5/16" FUEL INJECTION line and you'll be fine.
              Classic BMW Specialists
              Grover Beach, CA
              www.BimmerHeads.com
                Fuel injection hose is only needed for the high pressure lines. You can use ordinary fuel hose for the low pressure lines to save a bit of money. If you replace one hose at a time, no diagrams or docs are needed.
                  • 37832
                  You've got me there, I should have mentioned that as well.
                  Grover Beach, CA
                  www.BimmerHeads.com
                  • E30Gus
                    • Jun 2008
                    • 781
                    O'Reilly's has that junk by the foot. And most of it is FI rated. Should be stamped on the hose.
                    • jaydeep
                      • Jun 2011
                      • 208
                      SO just get fuel in going to fuel injection high pressure lines. Going back line to fuel tank ordinary fuel hose, correct?
                      • browntown
                        • Jun 2004
                        • 3524
                        Replacing the little lines by the fuel filter on late models requires the actual preformed lines from bmw. I tried it with regular fuel line and they kinked. I also invested in real oetiker clamps, which are not the easiest to deal with in confined spaces but are much tidier.
                        • colt
                          • Feb 2011
                          • 126
                          Not true. I bought some line a replaced it and it was fine. As long as you replace the hose and how its curved from factory.
                          • browntown
                            • Jun 2004
                            • 3524
                            OK, I'll rephrase, I didn't like the way the line looked plus if I remember right the 180 degree line is bigger on one end.
