Replacing drivers side door glass
  • Nick_S
    • Apr 2011
    • 3656
    I know I made a thread a few weeks ago but it only got one response so I'm hoping I can get an answer out of this one. My door glass came in the other day after the car got broken into. Trouble is I can't find a write up on how to re-install the glass, the Bentley manual doesn't cover late model window replacement and I for the life of me can't get it back on the track.
    This diagram from the previous thread shows the regulator. What I have is on the right...
    I can't get both rollers back on the track. I can get one or the other. There has to be some technique I'm missing or I do I have to remove the regulator or take a bolt out or something? Hoping someone can chime in and help out.
    Thanks
    Nick
    91 318is M50 swapped
    05 Honda Pilot
    24V swap thread
  • John in VA
    • Aug 2007
    • 553
    See Section 51, section 32:
    • b*saint
      • 3794
      Its a complete bitch.
      Ma che cazzo state dicendo? :|
      • Nick_S
        • Apr 2011
        • 3656
        Originally posted by John in VA
        Thanks for the link but unfortunately that's the same thing the Bentley shows, my window doesn't bolt the regulator at one end.
        05 Honda Pilot
        24V swap thread
        • b*saint
          • 3794
          My dad and I use a hole saw to access the other slider.
          • Nick_S
            • Apr 2011
            • 3656
            Ha wow. I figure out what seems like a much much easier way. On the larger rear track on the window. I used a heat gun and very gently pryed that off. Then simply ran the window into the front track, put the large track on the roller than just lowered the window onto it. Once in place, put a few dabs of epoxy and it's good to go. Took about 25 minutes.
            05 Honda Pilot
            24V swap thread
            • b*saint
              • 3794
              Hole saw it took 2 minutes. Its almost like BMW forgot to add another access hole.
              • Nick_S
                • Apr 2011
                • 3656
                Interesting...Well hopefully I won't have to do this again any time soon.
                05 Honda Pilot
                24V swap thread
