Hard start...calling jlevie
  • blocke
    • 1305
    My m20 has been exhibiting hard starts every time I start it. Hot, warm, cold...it takes a good 20-30 seconds and a few tries to fire up.
    I've tried the following:
    New injectors (thought they might be leaking)
    New-ish fuel pump
    New fuel filter
    Cleaned icv
    Checked tps
    New plugs,wires,coil,battery
    Checked fpr ( sucked on vacuum line)
    New valve cover gasket
    Checked for intake leaks
    Whatbto check next? Is there a way to test the check valve in the pump?
    Parts Wanted
    The Never-ending Resto Mod
  • Keith M
    • 2338
    Quoting Jim "do a smoke check to test for vacuum leaks"
    • nrubenstein
      • 3148
      I'd check/replace the CPS. Also, see if it's easier to start with the throttle wide open. The red car starts right up with the pedal down and I haven't cared enough to look into it. (It's my backup car/parts store runner.)
      2002 BMW M3 Alpinweiß/Black
      1999 323i GTS2 Alpinweiß
      1995 M3 Dakargelb/Black
      - S50B32/S6S420G/3.91
      1990 325is Brilliantrot/Tan
      1989 M3 Alpinweiß/Black
      • blocke
        • 1305
        This would indicate abflooding condition then? With WOT leaning it Out?
        Parts Wanted
        • nrubenstein
          • 3148
          Presumably. Or WOT just providing enough airflow to clear out the cylinders.
          That's separate from the CPS, though. Test that first because it can really screw you up in all kinds of ways.
