Remote locking system wont lock / unlock when wired up
  • cheezewiz
    • Jan 2004
    • 65
    Edit: see below... my solution sucked
  • StereoInstaller1
    GAS
    • 22679
    What model alarm are you using? I believe all Audiovox alarms need relays to be used, even though they have a negative output, it is only capable of triggering anout 500 mA, where the BMW needs to see more like 1 A of ground.
    It will work, but only for a while.
    If you need help wiring relays, I can do that, easy 'nuff.
    Luke
    Closing SOON!
    Thanks for 10 years of fun!
    • cheezewiz
      • Jan 2004
      • 65
      lol WELL THEN... maby i should fix that.... that makes a bit more sense.. *shrug*
      relays shouldent be an issue *sigh*
