Noticing an odd phenomenon with my 325i.
When i'm in a low gear, moving slowly, and let off the gas entirely, the car starts bucking back and forth pretty hard.
When I hit the brakes, the clutch, or give it some gas, the bucking stops.
Also seems to buck backwards pretty noticeably when shifting gears. Push the clutch in, and it lurches forward. Let it out, and it lurches backward.
RPM doesn't seem to rise or fall appreciably when it's doing this - i.e. the needle doesn't bounce with the car, stays steady. So I can't tell if it's the engine or something else.
Is this a suspension issue? Something with the transmission? You can definitely hear a whirring sound when you're in neutral with the clutch out that disappears when you push the clutch in. Diff issue maybe? I know my diff is a bit noisy.
