1987 325iS
24V Swap
Original Cluster when purchased and ALL functions working was an E30 M3 Cluster. VDO was the make. Tach, Odo, Fuel Gauge etc. All functioning.
Switch to VDO standard 325iS cluster. Remove the 'sim' that was on the ground lead for the tach. Reconnect as stock. Now I have everything working except for Fuel Gauge(1/2 is empty). This cluster has new gears installed and speedometer works but the cluster will not count miles.
Assume I actually need the Motometer based on the year. Purchase. Install. Functions are all the same as above. 1/2 is empty. No odometer counting... this is a known working cluster.
So what gives? How do I make all functions work properly? Without an E30 m3 cluster!
24V Swap
