Variations in C-101 connectors?
  • bflan2001
    • Sep 2007
    • 65
    I'm making a harness for my M10 to M42 swap. I bought a chassis-side C-101 pigtail to splice onto my M10 harness, but I'm running into an issue. I found the C-101 pin out diagrams online, and started testing my pigtail to make sure it was good to go. Every single wire I test is coming up a different color. Also, the unused pins are completely different from the diagrams. According to the info I found, pins 2, 3, 10, 17 & 19 are not used. The unused pins on my pigtail are 12, 15, 16 & 18. What the hell is going on?
    edit: i should note that i did not get the pigtail from the same e30 m42. the harness came from a late model e30 m20 (i was told they are identical).
  • bflan2001
    • Sep 2007
    • 65
    nevermind i figured out the issue. i was using the picture below and i just realized that it's a mirror image of what i'm looking at.
