Sunroof Problem!
  • Super-Eta
    • 53
    Sunroof Problem!
    I am having problems with my sunroof and dont know what to do.
    i was working on removing my sunroof panel when the T25 Hex screws decided to strip and it is not the hex screw itself its like the threaded holes the screw goes into that stripped and so now all what the screws does is spin and DO NOT come out and i am pissed becasue my sunroof is loose and i have no sunroof liner on it also i curently have one screw on each side removed.
    Please help.
  • Jordan
    • 12912
    You need to get the screw out.
    I think this is obvious.
    I don't think any of us can help you do what YOU need to do.
    yup.
    https://mtechniqueabs.com/
    • UNHCLL
      • 8790
      Try applying a little downward or sideways pressure on the nut as you turn it.
      Below the radar...
      • AndrewBird
        The Mad Scientist
        • 11898
        Well, since the hole is already stripped, an option might be to drill the bolt out. Start off by cutting the head of the bolt off with a dremal and a cut-off wheel. Then just use a drill and drill it out.
        Andrew
