OK Guy's
Replaced fuel pump, and filter and hoses, should it be necessary to pour fuel in the lines to eliminate the air that may cause vapor lock, or should the pump be able to handle it, my concern is vapor lock.
Let me know what your thoughts are.
Thanks
Barry
OK so I tried to pour fuel in line and still nothing. The fuel pump has no power even in start position. The wires to the gauge work perfect. I changed the harness before I had this problem, prior to the harness change the car ran perfect. I have a question that I might have wired something wrong. Here is the question- There is a wire that runs along the battery wire from the rear of the car, is that wire supposed to go to the lower nut on the fire wall battery block. I have an electrical problem with the fuel pump, the car turns over, no gas smell, pump does not work, seems there is no power to the pump motor only. Fuse 11 is ok fuel pump relay is new, pump is new, etc
If there is someone in or near Plano, Texas let me know. 1-954-980-0296
Thanks for your help
Barry
Thanks
Barry
Barry
