Need your help! No crank!!
  • JrCamacho
    • Feb 2011
    • 618
    I just installed a subwoofer and amp into my e30..
    Im very tech/car-audio savvy and know what i am doing. However after completing the install, my car wont crank.. I turn the key and... nothing.
    Radio and everything still works.
    My car: 1989 325i sedan Auto.
    I've check the neutral safety switch wiring, everything looks good there. I dont even get a little peep out of the starter.. Is there some main fuse or relay to check out? I also checked out the fusable link from the positive line from the battery and that was still good. Any suggestions? anything would be greatly appreciated!
    my car is stuck in the middle of the driveway... lol
    EDIT:
    I checked the starter, i am getting 12v to it. I also tried tapping it with my prybar while trying to crank to no avail....
    how does this happen when all i did was adding in an amp and sub?
  • bmwguy325is
    • May 2011
    • 1261
    Did you maybe trip the anti theft?
    sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
    The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
    • JrCamacho
      • Feb 2011
      • 618
      .. i had the battery disconnected for a while during the install... maybe disconnect and reconnect? Im going to try it.
      going through my repair manual.. it seems that i might have bad connections from the battery, im starting there.
      • JrCamacho
        • Feb 2011
        • 618
        is there a way around this? im not sure.
        • JrCamacho
          • Feb 2011
          • 618
          okay so i double checked my connections on the battery, cleaned terminals (were pretty clean to start) and reconnected.
          i still have the same problem..
          • JrCamacho
            • Feb 2011
            • 618
            ahh!! any advice would be great! my car is stuck in my driveway and i need to move it out of there, pushing it is no good as im on a hill...
            • 5Toes
              • 9836
              Lol I bet the car is not in park :)
              Happened to me the other day, dont worry
              • JrCamacho
                • Feb 2011
                • 618
                first post i stated that i checked the neutral safety switch. I put it in Park, Neutral, etc.. won't crank. its dark, im hungry, and im having a bitch of a time trying to figure out whats going on..
                I just UNDID the entire install of the sub and amp to no avail...
                double checked the fusible link in the trunk - good. WTF
                on a second note, i don't hear the starter's solenoid clicking while im trying to crank, could my starter be bad? i tested it and have 12v to it.
                • 5Toes
                  • 9836
                  Hmm I have no clue then
                  • JrCamacho
                    • Feb 2011
                    • 618
                    silly me, i didnt check the fuses with a test light, totally should have, anyways the one that shares with the instrument cluster was out.. lucky me.
                    oh yeah, i checked the operation of the starter by jumping pins 11 & 14 on the diagnostic port (20 pin) in the engine bay.
                    • ScottyB326
                      • Aug 2011
                      • 175
                      if the solenoid doesn't click then you still don't know if the starter is good or bad cuz it's not engaging. meaning no juice to the solenoid or the solenoid went bad. if it had clicked and then nothing then you start looking at the starter rather than the solenoid.
