brake lining light
    brake lining light
    guys' i recently put brake pads on all 4 wheels. i noticed that the front lining sensor was disconected and wire tied to the brake line. when i installed the fronts i diddn't replace the sensor cause the new pads where not equiped with the plug in. on the rears they where so i installed a new one. worked fine for 6 months and then the dash brake lining light started to flicker and with time stayed more on than off. i disconected the sensor from the pads but diddn't un plug the other end, wire tied it up also but the dash light still is illuminated. any ideas?? oh yea, the light seems to flicker when i hit bumps in the road.
    cut the end off.
    Ma che cazzo state dicendo? :|
      I removed the bulb from the instrument cluster.
      Done!
      1991 325ic and 1991 318is
        I think this is a common problem.. lol ..mine happened like 5 months ago.. at first I was concerned but then I got used to it... sometimes mine turn off if I switch my headlights and if I hit a bump it comes on again and stays on for awhile.. just replace your sensors..
          The brake light sensors, when new, are a continuous circuit (i.e., zero ohms). When the sensor contact the rotor that circuit is broken and the light turns on. So the light coming on when it shouldn't be incicates a falut in one of the snesors or in the wiring or in the cluster.
            Very likely solder joint in cluster. Simple test. Simple fix. Don't cut wires.
            Link to document I found on web: https://docs.google.com/document/d/1.../edit?hl=en_US
            Actually several documents combined into one I think.
