unknown random vacume hose.
    Well I'm just finishing putting my m20 back together and I've ran across a broken vacuum hose,I don't know the can its going into,I can only describe its location.
    This can with the hose is located right under the stater relays it looks like it has a fuel in but I haven't pulled it to check,but the other hose is broken and I can't find a hose male end anywhere.any help is needed,thanks.
    I think that the can your are referring to is the charcoal cannister. It will have one hose that connects to one of the hard lines that run to the rear of the car. The other fitting goes to the evap control valve that connects to the bottom of the throttle body.
    If you didn't mark the the two fuel hoses before disconnecting them from the engine, point both into a container and briefly jumper the fuel pump relay socket to run the pump. The hose fuel comes out of goes to the fuel rail. The other goes to the FPR.
      Very nice, I actually only unplugged the hose to the FPR,thank you jlevie
