So starting a few weeks ago, I would attempt to start my car and it would just crank. I turned the key and tried again and it would start. This slowly got worse where I had to try three times, four times, and crank longer each time till eventually it wouldn't start at all. I did some diagnostics and searched on here and thought it was the fuel pump (it wasn't getting power/ I couldn't hear it) So i changed the fuel pump relay (didn't fix it), then changed pump, and still nothing. I went back under the hood and noticed that the little four inch tube from the idle control valve to the throttle body was cracked. After sealing that up, I tried to start the car and it worked great (don't know if it was coincidence) but it started everytime i tired it that day. The next day, it didn;t start at all again, and i'm back to square one. And ideas on WTF the problem could be?
I'm stuck driving a brand new cr-v which sucks huge nuts. uncomfortable, slow, and terrrible on gas. So help a brotha get back to the luxury of an e30
