Steering rack question
  • mhuynh
    • Sep 2011
    • 63
    Both of the boots on my steering rack are ripped and I've contemplated on removing PS altogether. Can I just keep using it with the ripped boots are do I still have to replace it whether or not I keep PS.
    Also, is there a tutorial on how to remove PS the correct way?
  • Blackangusinc
    • Jul 2010
    • 244
    If you want to keep those sliding journals and arms clean and un-scored you should defiantly replace the boots.
    971-295-7077
    91' 318i
    • mhuynh
      • Sep 2011
      • 63
      How do I know if the seals are still good? The boot is dry.
        If the boots are dry, the seals are still okay.
        • mhuynh
          • Sep 2011
          • 63
          Yes, I still have ATF in the PS reservoir but nothing is coming out of the boot. I assume the steering rack is still useable. How hard is it to replace the boots? I found a guy selling a rack for $40 with good boots. Should I replace my boots or just swap out the whole rack?
          • Blackangusinc
            • Jul 2010
            • 244
            The boots are supposed to be dry. They are only there to keep dirt from destroying the seals.
            971-295-7077
            91' 318i
            • mhuynh
              • Sep 2011
              • 63
              Ok I think my rack is fine then. It just needs new boots.
              Although it is quite hard to turn....maybe my pump is on its way out...
              • Blackangusinc
                • Jul 2010
                • 244
                E30 racks are a little on the stiff side. You'll know if it is working when you pull the PS belt off and turn the wheel while the car is stationary. It should be a lot harder.
                971-295-7077
                91' 318i
                • Blackangusinc
                  • Jul 2010
                  • 244
                  Check out this link. http://www.r3vlimited.com/board/showthread.php?t=130389
                  971-295-7077
                  91' 318i
                  • mhuynh
                    • Sep 2011
                    • 63
                    I've never driven an E30 before so I wouldn't know how stiff it is. Maybe I'm just used to my 07 civic with electric power steering.
