I took my old VDO fuel pump to a shop and they plugged it into 12 volts and said it was DEAD.. I guess they confirmed the problem I had this weekend at the track.
I found a replacement Airtex pump that I can retrofit into the bracket for about 40.00.
I place power to it in order to see if I have the cables right and there is no movement..
Does the pump need to be submerged in order for it to work?
I'm troubleshooting to see if it's not a false alarm and I have a problem with the fuel pump relay/fuse.
Thanks in advance..
Thanks in advance..
