Ok so I am working on getting my car back on the road (replaced non-running M20 with a good one.) Over the course of getting things together the battery died on me, so I jump started the car and it ran fine for a couple minutes then died, no power at all, battery light on. Swapped out the alternator for another one, and I got the same result. Took both alternators and had them tested by a local parts shop, both are working.
So this leaves me wondering what to check next. I wouldn't be surprised if the battery is no good (it's fairly old.) But once the car is running, it should run off the alternator just fine until I shut the car off, correct? The other thing I am wondering, can the alternator test good if the voltage regulator isn't working? Is there any way to test the voltage regulator itself?
Car is an '87 325is. Thanks in advance for any help/suggestions, this car has been a 14 month project for me, and this is the last thing (until something else pops up...) standing between me and driving it for the first time.
